Known issues for Splunk SOAR Automation Broker
November 6, 2025 Release 7.1.0
This release of the Splunk SOAR Automation Broker has the following known issues:
Date filed Issue number Description
2025-11-19 PSAAS-26334
Internal_smtp asset throws [Errno 111] Connection refused when internal Automation Broker is used
Workaround: Set up your own smtp to send emails, rather than using internal_smtp.
2025-03-28 PSAAS-22672
Automation Broker shows inactive status although it continues to function well
Workaround: Pause between stopping and starting the AB to prevent this condition.
September 2, 2025 Release 7.0.0
Known Issues section for release 7.0.0
June 06, 2025, 6.4.1.361
This release of the Splunk SOAR Automation Broker has no known issues.
May 22, 2025, 6.4.1.355
May 22, 2025, 6.4.1.353
Issue number Date filed Description
PSAAS-23675 2025-05-22 Automation Broker is missing libpq5 in 6.4.1.353
Workaround:
Do one of the following actions:
  • Install Automation Broker release 6.4.1.355
  • Update your existing Automation Broker release 6.4.1.353 with the missing library.
To update your existing AB container do the following steps:
  1. Get the container
    CODE
    ID.docker ps
  2. Update the the container.
    CODE
    docker exec <CONTAINER_ID>
    apt updatedocker exec <CONTAINER_ID>
    apt install libpq5
April 10, 2025, 6.4.0.93
March 27, 2025
February 20, 2025
PSAAS-21996 2025-02-11 Update progress fails for older ABs due to a validation error
PSAAS-21652 2025-01-30 cloud apps depend on modules that use Google authentication failing on cloud instance with AB
PSAAS-16477 2024-02-22 Podman does not currently work with redirected image URLs due to Docker Hub authentication token changes
PSAAS-16431 2024-02-15 Automation Broker: Actions intermittently hang for Automation Broker when there are connection issues
Work around:
  1. Check if the action completed successfully.
  2. Cancel the hanging action.
  3. If the action did not complete successfully, re-run the action.
PSAAS-14159 2024-07-24 Automation Broker: Jira 'get attachment' action fails over AB due to SSL check error
November 13, 2024
PSAAS-19811 2024-09-26 save_progress method not outputting to Playbook Debugger when bound to Automation Broker
PSAAS-16206 2024-01-30 SOAR Global Environment Variables are incorrectly applied by the Automation Broker when the variable is named in all lowercase letters.
Workaround:
When naming Global Environment Variables in SOAR use only uppercase letters.
PSAAS-14609 2023-08-25 Broker status should be updated if the broker directory is no longer present
September 19, 2024
PSAAS-14609 2023-08-25 AB: Broker status should be updated if the broker directory is no longer present
PSAAS-16206 2024-02-30 SOAR Global Environment Variables are incorrectly applied by the Automation Broker when the variable is named in all lowercase letters.
Work around:
May 29, 2024
Work around:
March 28, 2024
Work around:
Work around:
November 30, 2023
September 07, 2023
July 12, 2023
2023-06-13 PSAAS-13738, PSAAS-13775 Automation Broker doesn't show correct version in SOAR web-based UI (always show version 0.1)
Workaround: To get the broker version from the container, run the following: docker exec -ti <container_id> /splunk/broker/bin/brokerd -v Sample run results:
CODE
docker exec -ti 7658b164a1e3 /splunk/broker/bin/brokerd -v        1.1m
Tue Jun 13 14:09:44 2023
Brokerd version: 6.0.0.114895
May 17, 2023
February 22, 2023
Known Issues for 2022 releases
No known issues for 2022 releases.
