Fixed issues for Splunk SOAR Automation Broker
Release 8.6.0 and higher
fixed issues for release 8.6
Automation Broker fixed issues are included in Fixed issues for Splunk SOAR (Cloud).
April 8, 2026 Release 8.5.0
Fixed issues in this version of Splunk SOAR Automation Broker
This version of Automation Broker contains the following fixed issues. If no issues are listed, there are no fixed issues.
February 4, 2026 Release 8.4.0
| Date resolved | Issue number | Description |
| 2026-02-14 | PSAAS-27561 | REST API log sink uses stale token after rotation |
November 6, 2025 Release 7.1.0
Fixed issues in Splunk SOAR Automation Broker version 7.1.0
This release of the Splunk SOAR Automation Broker has no fixed issues.
September 2, 2025 Release 7.0.0
Fixed issue for Automation Broker 7.0.0
| 2025-06-08 | PSAAS-23555 | SOAR 6.4.0 playbook debugger gets stuck in Status: Running! |
June 06, 2025 6.4.1.361
May 22, 2025 6.4.1.355
| 2025-05-22 | PSAAS-23675 | Automation Broker is missing libpq5 in 6.4.1.353. |
May 22, 2025 6.4.1.353
| 2025-04-15 | PSAAS-22813 | Automation Broker: 'last rotated time' is not updated when a user gets new credentials from UI. |
| 2025-04-15 | PSAAS-22633 | Test Connectivity doesn't output anything when using an AB |
| 2025-04-15 | PSAAS-22492 | Improve Healthcheck stdout output |
April 10, 2025, 6.4.0.93
March 27, 2025
February 20, 2025
| 2025-01-27 | PSAAS-14609 | Automation Broker: Broker status should be updated if the broker directory is no longer present |
| 2024-12-23 | PSAAS-16206 | Global Environment Variables are incorrectly applied by the Automation Broker when the variable is named as all lowercase letters |
| 2025-01-28 | PSAAS-16959 | Enabling the Secret Flag in Global Environment Variables Causes AB Test Connectivity/Poll Now to Fail |
| 2025-01-28 | PSAAS-19811 | save_progress method not outputting to Playbook Debugger when bound to Automation Broker |
November 13, 2024
| 2024-11-06 | PSAAS-19993 | Automation Broker healthcheck does not work due to ModuleNotFoundError: No module named 'phantom' |
September 19, 2024
| 2024-09-05 | PSAAS-19242 | Git connector 'test connectivity' and 'clone repo' are failing on Automation Broker, because 'git remote-http' command is missing in AB container |
