The Splunk platform
The Splunk platform encompasses both Splunk Enterprise and Splunk Cloud Platform, serving as a noun or modifier in various contexts.
Use "the Splunk platform" to refer to both Splunk Enterprise and Splunk Cloud Platform. You can use "the Splunk platform" either as a noun or as a modifier.
Before you use a general term like the Splunk platform, consider whether a specific component of the product, like the search head, the indexer cluster, Splunk Web, the data collection node, the deployment server, the forwarder, and so on, is more helpful for customers. See Splunk platform architecture components.
As a noun
When using "the Splunk platform" as a noun, follow these conventions:
  • Include a definite article.
  • Don't capitalize the "p" in "platform".
  • Don't use "the Splunk platform" in the possessive form, which can dilute the trademark. See Trademark attribution.
Review the following table for examples of correct usage:
"" Do this "" Don't do this
the Splunk platform The Splunk Platform
Splunk platform
the searching capabilities of the Splunk platform the Splunk platform's searching capabilities
As a modifier
You can use "the Splunk platform" or "Splunk platform" without a definite article as a modifier. Avoid using "Splunk" as a modifier by itself when you are referring to a specific instance where the Splunk platform is installed, Splunk platform deployments, or the environment in which the Splunk platform is running.
Restart the Splunk platform instance... Restart the Splunk instance…
In a distributed Splunk platform deployment... In a distributed Splunk deployment…
In your Splunk platform environment... In your Splunk environment…
Don't capitalize Splunk platform architecture components such as indexers, forwarders, search heads, license managers, and deployment servers. If you are unsure how to capitalize a Splunk software term, see the Splexicon for the correct capitalization.
