Types of forwarders
There are three types of forwarders:
  • The universal forwarder contains only the components that are necessary to forward data.
  • A heavy forwarder is a full Splunk Enterprise instance that can index, search, and change data as well as forward it. The heavy forwarder has some features disabled to reduce system resource usage.
  • A light forwarder is also a full Splunk Enterprise instance, with more features disabled to achieve as small a resource footprint as possible. The light forwarder has been deprecated as of Splunk Enterprise version 6.0. The universal forwarder supersedes the light forwarder for nearly all purposes and represents the best tool for sending data to indexers.
