Edge Processor pipeline syntax
A pipeline is a Search Processing Language, version 2 (SPL2) module containing a $pipeline statement that specifies what data to process, how to process it, and what destination to send the processed data to. To configure an Edge Processor to process and send data, you must create pipelines and apply them to your Edge Processor.
The Edge Processor solution supports a subset of SPL2 commands and functions. When creating a pipeline, you can use only the commands and functions that are part of the edgeProcessor profile. Additionally, when using a command or function that uses regular expressions, you must write the regular expressions in Perl Compatible Regular Expression 2 (PCRE) syntax. For information about the SPL2 and regular expression features that are supported for Edge Processor pipelines, see the following sections on this page:
- SPL2 syntax for Edge Processor pipelines
- SPL2 commands for Edge Processor pipelines
- SPL2 evaluation functions for Edge Processor pipelines
- SPL2 operators for Edge Processor pipelines
- Regular expression syntax for Edge Processor pipelines
For more information about profiles, see SPL2 compatibility profiles in the SPL2 Search Reference.
When you create an Edge Processor pipeline in the pipeline builder, you create an SPL2 statement that uses the following syntax:
$pipeline = | from $source | <processing command> | into $destination;
The following table explains how each part of this pipeline syntax determines the data processing behavior by the Edge Processor that the pipeline is applied to:
| Pipeline syntax | Required? | Description |
$pipeline |
Yes | A variable indicating that the current SPL2 statement is a pipeline instead of a search query. |
from $source |
Yes | A command that instructs the Edge Processor to process a subset of the incoming data. This subset is determined by the partition of the pipeline, which you configure using the pipeline builder. See Create pipelines for Edge Processors for more information. |
| <processing command> | No | One or more SPL2 commands that determine how the Edge Processor handles data. Each command must be delimited by a pipe ( | ). See the following sections on this page for more information:
If you don't include any processing commands, the Edge Processor sends data to the destination without changing the data. |
into $destination |
Yes | A command that instructs the Edge Processor to send data to a given destination. You specify the destination using the pipeline builder. See Create pipelines for Edge Processors for more information. |
You can use the following SPL2 commands in your pipelines.
Each pipeline must include the from and into commands, as described in the SPL2 syntax for Edge Processor pipelines section on this page. You can optionally use the other commands in this list as processing commands in your pipeline.
- branch
- decrypt
- eval
- expand
- fields
- flatten
- from
- into
- lookup
Note: Before you can use the
lookupcommand in an Edge Processor pipeline, you must import a lookup dataset into the pipeline. See Importing datasets into Edge Processor pipelines on this page and Enrich data with lookups using an Edge Processor for more information. - mvexpand
- ocsf
- rename
- replace
- rex
Note: Starting on March 5, 2025, all new pipelines will use PCRE2 syntax by default, with no option to use RE2. All existing pipelines can continue using RE2. Starting in June 5, 2025, RE2 support ends completely. All pipelines (new and existing) must use PCRE2 syntax. See Regular expression syntax for Edge Processor pipelines on this page for more information.
- route
- stats
- thru
- where
You can use the following evaluation functions in your eval and where commands:
| Type of function | Evaluation function |
| Comparison and conditional functions |
| Conversion functions | |
| Cryptographic functions | |
| Date and time functions | |
| Informational functions | |
| JSON functions | |
| Mathematical functions | |
| Multivalue eval functions | |
| Pipeline functions | |
| Statistical eval functions | |
| Text functions |
| Trig and hyperbolic functions |
SPL2 statistical functions for Edge Processor Pipelines
You can use the following operators in your processing commands:
| Type of operator | Operator | Documentation |
| Relational operators |
See Relational operators in the SPL2 Search Manual. |
| Logical operators |
See Logical operators in the SPL2 Search Manual. |
| Arithmetic operators |
See Arithmetic operators in the SPL2 Search Reference. |
| Other operators | IN | See IN operator in the SPL2 Search Manual. |
The Edge Processor solution supports Perl Compatible Regular Expressions 2 (PCRE) syntax. All Regular Expression 2 (RE2) syntax must be replaced with PCRE syntax. When you use a command or function that uses regular expressions, such as the rex command or the replace evaluation function, you must write the regular expressions in PCRE syntax.
To learn about RE2 syntax and the differences between RE2 and PCRE, see https://github.com/google/re2/wiki/Syntax in the Google RE2 repository on GitHub.
Additionally, be aware that named capture groups must be written using this format:
(?P<fieldName>regular expression capture pattern)
Named capture groups are typically used in SPL2 statements to extract data values from the event body into fields. For example, to create an Edge Processor pipeline that extracts HTTP status codes from the event body into a field named httpcode, you need to include the following rex command and named capture group:
rex field=_raw /(?P<httpcode>[1-5][0-9][0-9])/
When configuring a pipeline, you can import datasets for the pipeline to use by adding an import statement before the $pipeline statement.
For example, you can import a lookup dataset, and then use the lookup command to configure a pipeline that enriches the received data with additional information from the lookup dataset. In this case, your pipeline would be an SPL2 module that contains the following 2 statements:
import <dataset_name> from <namespace>
$pipeline = | from $source | lookup <dataset_name> <lookup_field> AS <event_field> | into $destination;
The namespace contains the name of your Edge Processor tenant. The tenant name, dataset name, and field names must be enclosed in single quotation marks ( ' ) if either of the following conditions are true:
- The name begins with anything other than a-z, A-Z, or the underscore ( _ ) character.
- The name contains anything other than a-z, A-Z, 0-9, or the underscore ( _ ) character.
import statement and the lookup command to your pipeline.
When you add an import statement, you are not physically importing an item into the SPL2 module. Instead, you are adding a pointer to an item that resides in another module or namespace. When you use the item in a statement, the item is retrieved from the source. For more information, see Importing module items and datasets using SPL2 in the SPL2 Search Manual.
See also
For more information about pipelines and Edge Processors, see the following pages in this manual:
For more information about modules and statements as SPL2 concepts, see Modules and SPL2 statements in the SPL2 Search Manual.
