Edge Processor metrics reference
As an Edge Processor administrator, you can create dashboards to monitor the health, status, and information of the data that is flowing through your Edge Processors. You can do this from your Splunk platform deployment. For more information on creating dashboards, see About dashboards.
You can create these queries by using the Search & Reporting app in the Splunk platform. Aside from searching and creating dashboards to monitor your Edge Processor, you can configure alerts to notify specific changes that you would like to track. For more information on how to configure alerts in the Splunk platform, see Getting started with alerts.
S2S ACK performance benchmarks
The following results compare Splunk-to-Splunk (S2S) throughput with and without end-to-end acknowledgment (ACK) for standalone and hybrid Edge Processor deployments. Hybrid ACK results include the default one-connection test and a tuned test using 4–6 ingestion connections.
| Workload and metric | Standalone, non-ACK | Standalone, ACK | Hybrid, non-ACK | Hybrid, ACK (default, 1 connection) | Hybrid, ACK (tuned, 4–6 connections) |
| Windows event log, events per second (EPS) | 80,000 | 100,000 | 45,000 | 40,000 | 62,000 |
| Windows event log, throughput (MB/s) | 67.7 | 84.5 | 38 | 33.6 | 53 |
| Windows event log, p95 ACK latency | Not applicable | 3–5 s (CCM) | Not applicable | 2.4–22 s (average 2.4–3.3 s) | 2.3–17 s (average 1.6–2.5 s) |
| Syslog, events per second (EPS) | 190,000 | 120,000 | 65,000 | 80,000 | 112,000 |
| Syslog, throughput (MB/s) | 16.8 | 10.4 | 5.7 | 6.3 | 9.8 |
| Syslog, p95 ACK latency | Not applicable | About 10 s (CCM) | Not applicable | Not reported | 3.7–5.7 s (average 1.1–1.5 s) |
EP Hybrid performance benchmarks
EP Hybrid runs the Edge Processor alongside a Splunk heavy forwarder (HF). In this mode, Splunkd handles input and parsing before data passes to EP over the local IPC connection. The results below are from the EP 1.13.1 internal benchmark presentation and are workload-specific.
| Workload and metric | Standalone EP | EP Hybrid | Hybrid CPU and memory |
| Windows event log, EPS | 80,000 (80 connections) | 45,000 (1 connection) | CPU about 330% total (EP 210%, HF 120%); memory about 4.1 GiB total (EP 2.7 GiB, HF 1.4 GiB) |
| Windows event log, throughput | 67.7 MB/s | 38 MB/s | See resource use in the row above |
| Syslog, EPS | 190,000 (190 connections) | 65,000 (1 connection) | CPU about 280% total (EP 190%, HF 90%); memory about 4.3 GiB total (EP 2.9 GiB, HF 1.4 GiB) |
| Syslog, throughput | 16.8 MB/s | 5.7 MB/s | See resource use in the row above |
| Input path | Sample maximum EPS | Throughput (MB/s) | Conditions |
| TCP syslog to EP syslog | 78,000 | 6.66 | Untuned |
| TCP syslog to EP Windows event log | 45,000 | 37.82 | Untuned |
| UDP syslog to EP syslog | 74,750 | 6.33 | Untuned |
| UDP syslog to EP Windows event log | 10,360 to about 41,000 | 8.77 to about 34.7 | Untuned to kernel and buffer tuned |
| HEC to EP syslog | 120,000 | 10.47 | parallelIngestionPipelines=2 |
| HEC to EP Windows event log | 73,000 | 62 | parallelIngestionPipelines=2 |
| AWS instance type | EP CPU / HF CPU | EP memory / HF memory (GB) | Throughput (MB/s) | Ingest (TB/day) | Ingestion pipelines / sent to EP (%) |
| c6a.large (2 vCPU, 4 GiB RAM) | 130% / 50% | 2.1 / 0.6 | 10.9 | 0.94 | 1 / 80.3% |
| c6a.xlarge (4 vCPU, 8 GiB RAM) | 200% / 70% | 2.3 / 0.6 | 22.5 | 1.94 | 2 / 82.9% |
| c6a.2xlarge (8 vCPU, 16 GiB RAM) | 500% / 200% | 2.6 / 0.8 | 38.1 | 3.29 | 4 / 87.7% |
The real-world reference is a test using Palo Alto Networks firewall and URL logs sent from a heavy forwarder through a Splunk processing pipeline to EP. Its dataset and methodology differ from the other benchmark rows. Edge Processor sizing guidelines also describe internal S2S performance testing and advise evaluating throughput for the specific deployment.
Tuning results were conducted on an 8 vCPU, 16 GiB host, scaling ingestion pipelines for S2S with ACK increased Windows event log throughput from 33.6 to 53 MB/s (+58%) and syslog throughput from 6.3 to 9.8 MB/s (+55%). For HEC with two ingestion pipelines, syslog increased from 65,000 to 120,000 EPS (+85%) and Windows event log increased from 45,000 to 73,000 EPS (+62%). Increasing ingestion pipelines does not improve TCP or UDP syslog paths in this test because Splunk pins those paths to one pipeline. Setting maxKbps to 0 removes the default per-pipeline 256 kbps limit. UDP receive-buffer tuning increased Windows event log syslog from 10,360 to about 41,000 EPS, though packet-receive errors rose above about 20,000 EPS; the presentation recommends TCP syslog for events consistently larger than 1,400 bytes.
Data processing metrics
Use these metrics to monitor data that the Splunk-to-Splunk (S2S) receiver discards before it passes the data to a pipeline. The S2S receiver accepts data from universal and heavy forwarders. These counters are available in Edge Processor 1.14.0 and higher.
| Metric | Metric name | Unit | Labels |
| Discarded records and metric data points | ingress_dropped_records_total |
Count | reason, disposition |
| Discarded event metadata fields, counted separately from records | ingress_dropped_fields_total |
| Acknowledgements that the receiver will not send to a forwarder | ingress_abandoned_ack_ids_total |
Each metric counts a different unit: records, fields, or acknowledgements. Do not add the metric values together. The metrics are counters for each Edge Processor instance. They do not identify a pipeline, source type, or forwarder. For those details, review the Edge Processor log message for the discard. Edge Processor samples its logs, so a log message might not exist for every discard.
Metric label reference
The disposition label describes what a discard means for the data.
| Value | Meaning | What to do |
lost |
The data will not reach its destination. The connection does not use acknowledgement, or the receiver already acknowledged the data. | Investigate. To make these discards recoverable, enable indexer acknowledgement on your forwarders by setting useACK = true in outputs.conf. |
resend_expected |
The receiver discarded the data before acknowledging it. The forwarder still has the data and resends it. | No action is needed unless the rate stays high. A sustained rate means data is delayed and resent repeatedly. |
duplicate_possible |
The receiver delivered the data but did not send the acknowledgement. The forwarder resends data that was already delivered, so duplicate events are possible. | Check the destination for duplicate events. |
expected |
The S2S protocol requires this discard. It is not a fault, and no data is lost. | No action is needed. Do not count these discards as data loss. |
Whether a discard has the lost or resend_expected disposition depends on whether the connection uses acknowledgement. The receiver uses acknowledgement on a connection only when the forwarder requests it with useACK = true.
The reason label identifies why the receiver discarded the data.
| Reason | Metric | When it happens | Possible dispositions |
consumer_error |
Records | The receiver could not pass a batch of records to the pipeline. | resend_expected with acknowledgement; otherwise lost |
unknown_channel |
Records, fields | Data arrived for a forwarder channel that the receiver no longer tracks. | resend_expected with acknowledgement; otherwise lost |
field_name_unresolved |
Fields | The receiver could not resolve the name of a metadata field. The event is still delivered without that field. | lost |
channel_evicted |
Acknowledgements | The receiver closed a forwarder channel before the forwarder ended it, for example, because the connection opened too many channels. | resend_expected with acknowledgement; otherwise lost |
empty_batch |
Acknowledgements | An acknowledgement belonged to a batch that contained no records to deliver. | resend_expected with acknowledgement; otherwise lost |
ack_sender_closed |
Acknowledgements | The receiver delivered the data, but the connection closed before it sent the acknowledgement. | duplicate_possible |
flush_marker |
Acknowledgements | The forwarder ended a data stream while an event was incomplete. The forwarder resends the incomplete part on its next connection. | expected without acknowledgement; with acknowledgement, duplicate_possible when the receiver withholds the acknowledgement so the forwarder replays an event that spans several chunks. |
The most frequent discard is flush_marker with the expected disposition. It occurs once per channel each time a forwarder rotates its connection. You set how often the forwarder rotates its connection.
Example searches for Edge Processor metrics
Use these searches to monitor records lost per Edge Processor host and to review all discards by reason and disposition, including protocol-required discards.
Rate of records lost per Edge Processor host:
| mstats rate_sum(ingress_dropped_records_total) as discarded WHERE index=_metrics sourcetype=edge-metrics disposition="lost" span=5m by host
| timechart max(discarded) as "records/s" by host
All discards by reason and disposition:
| mstats rate_sum(ingress_dropped_records_total) as records rate_sum(ingress_dropped_fields_total) as fields rate_sum(ingress_abandoned_ack_ids_total) as acks WHERE index=_metrics sourcetype=edge-metrics span=1m by reason disposition
| stats sum(records) as records sum(fields) as fields sum(acks) as acks by reason disposition
To exclude protocol-required discards from a search, add NOT disposition="expected".
Searching for Edge Processor metrics
The Edge Processor metrics are stored in the _metrics index. To access these metrics, use the mstats command. The following table contains the common query patterns used to search for these metrics.
| Stats metric term | When to use |
Rate_sum() |
Counters |
Latest() |
Gauges |
Avg() |
Averages over time |
Perc95() |
Latency percentiles |
An example query syntax would look like the following:
mstats rate_sum(metric_name) WHERE index=_metrics span=1m
To see more information on Edge Processor example searches for common metrics, see Example searches for Edge Processor metrics.
Throughput metrics
Use these metrics to track how data moves from ingestion to destination.
Track the rate at which data is successfully processed through the Edge Processor instance over a specific period. The following table lists the metrics that track this information.
| Metric | Metric name | Unit | Label |
| Data received by processor | processor_bytes_in_total |
Bytes | dataset_name, evt_source_type, signal_type |
| Data sent by processor | processor_bytes_out_total |
| Events received | processor_events_in_total |
Event count | dataset_name, evt_source_type |
| Events sent | processor_events_out_total |
Egress data metrics
Track the rate at which outbound data is sent from the Edge Processor to an external destination over a specific period. The following table lists the metrics that track this information.
| Bytes written to destination | egress_bytes_written_total |
Bytes | exporter_type, dataset_name, signal_type |
| Send attempts including retries | write_to_sink_attempts_total |
Count | exporter_type, dataset_name |
| Export errors | export_destination_errors_total |
Count | exporter_type, dataset_name, errorType |
| Write latency to destination | write_to_sink_latency_seconds |
Histogram | exporter_type, dataset_name, signal_type |
| Logs successfully sent | exporter_sent_log_records |
Count | exporter |
| Metrics successfully sent | exporter_sent_metric_points |
Count | exporter |
| Spans successfully sent | exporter_sent_spans |
Count | exporter |
| Failed log sends | exporter_send_failed_log_records |
Count | exporter |
| Failed metric sends | exporter_send_failed_metric_points |
Count | exporter |
| Failed span sends | exporter_send_failed_spans |
Count | exporter |
Queue metrics
Track the data flowing through the queue and retries over a specific period. The following table lists the metrics that track this information.
| Metric | Metric name | Unit | Type |
| Current queue size (entries) | queue_size_entries |
Count | Gauge |
| Current queue size (bytes) | queue_size_bytes |
Bytes | Gauge |
| Maximum queue capacity | queue_max_bytes |
Bytes | Gauge |
| Undispatched entries | queue_undispatched_entries |
Count | Gauge |
| Bytes written into queue | enqueued_entries |
Count | Counter |
System and host metrics
Process metrics
Use these metrics to track the health or performance of your host or machine.
Monitor the health of the process of your Edge Processor by using these metrics in your search. The following table lists the metrics that track this information.
| Process uptime | process_uptime |
Seconds | - |
| Physical memory usage | process_memory_rss |
Bytes | - |
| Heap memory allocated | process_runtime_heap_alloc_bytes |
Bytes | - |
| CPU time used | process_cpu_seconds |
Seconds | state |
Host metrics
Monitor the health of your host by using these metrics in your search. The following table lists the metrics that track this information.
| CPU usage by state | system.cpu.time, system.cpu.utilization |
Seconds, ratio | CPU, state |
| RAM usage by state | system.memory.usage, system.memory.utilization |
Bytes, ratio | state |
| Disk I/O operations and throughput | system.disk.io, system.disk.operations |
Bytes, count | device, direction |
| File system capacity and usage | system.filesystem.usage, system.filesystem.utilization |
Bytes, ratio | device, mountpoint, type, state |
| Network traffic and errors | system.network.io, system.network.errors, system.network.packets, |
Resource identification labels
The following tables contain corresponding labels for specific metrics.
| Metric attribute | Label | Example |
| Unique supervisor instance ID | service_instance_id |
sup-abc123 |
| Supervisor group ID | processor_id |
group-1 |
| Tenant ID | tenant |
tenant-xyz |
| Machine host name | host_name |
edge-host-01 |
Pipeline and component labels
| Pipeline ID | pipeline_id |
7200faed6f099ed392c155e339e5ddea_1777916602202068260_rjlqv |
| Exporter component ID | exporter |
S2S/shared.pipelines.default_splunk_cloud_destination |
| Type of exporter | exporter_type |
awss3, splunkhec, splunk |
| Receiver component ID | receiver |
“*hecreceiver” |
| Transport protocol | transport |
http |
Data classification labels
| Telemetry type | signal_type |
logs, metrics |
| Dataset name | dataset_name |
| Dataset kind | dataset_kind |
hecreceiver |
| Source type | evt_source_type |
access_combined |
| Agent hostname | agent |
agent-host-01 |
| Internal index flag | internal |
True, False |
| Error category | error_type |
Unclassified, DestinationError, ConnectionForbidden, HostNotFound, InvalidRequest. ResourceNotFound, |
The following table highlights the searches that you can use to create dashboards for Edge Processor metrics. For more information on how to create dashboards to monitor your Edge Processor health, see About dashboards.
| Metrics | Example search |
| Edge Processor data throughput overview | | mstats sum(processor_bytes_in_total) as bytes_in sum(processor_bytes_out_total) as bytes_out sum(egress_bytes_written_total) as bytes_egress WHERE index=_metrics span=5m | eval in_mb = round(bytes_in / 1024 / 1024, 2) | eval out_mb = round(bytes_out / 1024 / 1024, 2) | eval egress_mb = round(bytes_egress / 1024 / 1024, 2) | timechart span=5m avg(in_mb) as "Processor Input (MB)" avg(out_mb) as "Processor Output (MB)" avg(egress_mb) as "Egress (MB)" |
| Edge Processor queue health | | mstats latest(queue_size_bytes) as queue_bytes latest(queue_max_bytes) as queue_capacity WHERE index=_metrics by host_name span=1m | eval queue_usage=round(queue_bytes/queue_capacity*100, 2) | timechart max(queue_usage) as queue_usage by host_name useother=f usenull=f |
| Edge Processor processing latency | | mstats rate(_value) as time_cost WHERE index=_metrics host="*" metric_name=*processor_processing_time_bucket by _timeseries, le, pipeline_id span=5m | stats sum(time_cost) as total_time_cost by _time, le, pipeline_id | sort _time, pipeline_id, le | eventstats max(total_time_cost) as total_hist_rate, last(le) as uppermost_bound, count as num_buckets by _time, pipeline_id | eval rank=exact(0.95)*total_hist_rate | streamstats current=f last(le) as gr, last(total_time_cost) as last_hist_rate by _time, pipeline_id | eval gr=if(isnull(gr), 0, gr), last_hist_rate=if(isnull(last_hist_rate), 0, last_hist_rate) | where total_time_cost >= rank | dedup _time, pipeline_id | eval res=case(lower(uppermost_bound) != "+inf" or num_buckets < 2, "NaN", lower(le) == "+inf", gr, gr == 0 and le <= 0, le, true(), exact(gr + (le-gr)*(rank - last_hist_rate) / (total_time_cost - last_hist_rate))) | fields _time, pipeline_id, res | rename res as "histperc" | timechart max(histperc) by pipeline_id |
| Edge Processor resource utilization | | mstats latest(process_memory_rss) as memory latest(process_runtime_heap_alloc_bytes) as heap WHERE index=_metrics BY service_instance_id span=1m | eval memory_mb = round(memory / 1024 / 1024, 2) | eval heap_mb = round(heap / 1024 / 1024, 2) | timechart span=1m avg(memory_mb) as "RSS Memory (MB)" avg(heap_mb) as "Heap Memory (MB)" |
| Top datasets by volume in Edge Processor | | mstats sum(processor_bytes_in_total) as bytes WHERE index=_metrics BY dataset_name span=1h | eval gb = round(bytes / 1024 / 1024 / 1024, 3) | stats sum(gb) as total_gb by dataset_name | sort -total_gb | head 10 |
| Edge Processor exporter comparison | | mstats sum(egress_bytes_written_total) as bytes perc95(write_to_sink_latency_seconds) as latency sum(exporter_errors_total) as errors WHERE index=_metrics BY exporter_type span=5m | eval gb = round(bytes / 1024 / 1024 / 1024, 3) | stats avg(gb) as avg_gb avg(latency) as avg_latency_sec sum(errors) as total_errors by exporter_type |
| Edge Processor agent ingestion breakdown | | mstats sum(processor_bytes_in_by_agent_total) as bytes WHERE index=_metrics BY agent span=1h | eval gb = round(bytes / 1024 / 1024 / 1024, 3) | stats sum(gb) as total_gb by agent | sort -total_gb |
