Send data to an Edge Processor using HEC
Configure your HTTP client or logging agent to make HTTP POST requests to a supported HEC endpoint on an Edge Processor instance. If your Edge Processor has multiple instances, then you must make the HTTP requests to either a specific instance or a load balancer that is configured to pass incoming requests to multiple instances.
curl command to generate the request, but you can use any tool or application that is compatible with the HTTP and REST specifications.
For information about the supported HEC endpoints, including the use case of each endpoint and examples that demonstrate how requests to different endpoints result in different data ingestion behavior by the Edge Processor, see Usage information and examples for supported HEC endpoints in this topic.
Depending on which HEC endpoint you're using, you need to format your HTTP requests differently. See Requirements and best practices for requests to HEC endpoints in Edge Processors in this topic.
