Monitor Observations
The Observations page describes the runtime events that do not violate a policy or that are not considered to be an attack. These can be normal runtime behavior where the events may impact the security, but any malicious intent is not determined. For example, an application opening a file outside the application directory causes Observed state. You can use this information in investigating incidents to understand the historical behavior of an application and in defining the runtime policy.
The Observations page includes these details:
Name Description
ID
The ID of the corresponding Observation. Secure Application generates this ID. You can modify this ID on the Observation details page. To view the Observation details page, click the desired row.
Source
The source of the corresponding Observation. This provides information on these types of the observation:
  • Internal: When the events are detected from an internal source.
  • External: When the events are detected from an external source.
  • Unknown: When the source of the runtime behaviour is not known.
Events The type of the observation and count of that observation type.
Observation Type
Observation types include:
  • API: The agent detected an outgoing socket connection from the application stack.
  • COMMAND: The agent detected a local command was forked by the application stack.
  • DESERIAL: The agent detected a Java class deserialization event.
  • LFI: The agent detected a file read, file write, or file delete event.
  • NETWORK:This agent detects network connections to specific hosts.
  • PATH: The agent detected a path traversal event in the application stack.
  • SQL: The agent detected a non-parameterized SQL command.
  • VULN: The agent detected and unsafe cookie, unauthenticated access, or clear text HTTP event.
Application
The application affected by the observation.
Tier (Nodes)
to launch the application flow map in the Splunk AppDynamics dashboard. The info icon next to an affected tier indicates that the observed nodes in the tier include critical or medium vulnerability.
Last Detected
The time that is elapsed since the last event within the observation.
Click this field to sort the values in ascending or descending order.
