TCP Connection Metrics in Metric Browser
Network Visibility Agents can calculate an extensive set of metrics based on the TCP flows observed by the Network Agents. In addition to KPI, PIE, and Troubleshooting metrics, you can view advanced metrics for network elements of interest (tiers, nodes, links, and connections) in the Metric Browser. Using time-based charts, you can detect and analyze these behavior traits:
  • TCP flow setup/teardown times and errors
  • Distribution of TCP flows for an element by throughput, setup time, lifetime, and round-trip time
  • Flows closed by TCP resets
  • Distribution of flows based on TCP configuration options (Selective Acknowledgement, Timestamp)
Note:
  • For these metrics, the Metric Browser uses the terms Connection and Flow interchangeably. See Flows, Links, and Connections.
  • Network Agents do not collect metrics for individual Connections by default. The recommended workflow is to enable TCP Flow metric collection only when you need to diagnose a performance issue on an associated node or Connection. See Dynamic Monitoring Mode and Network Visibility.
Viewing TCP Flow Metrics
To view advanced network metrics, open the Metric Browser and navigate to Application Infrastructure Performance. The Metric Browser shows connection/flow metrics for the following aggregations (highlighted in red):
  • Application Infrastructure Performance >
    • Advanced Network >
      • Flows >
        • All Connections/Flows for Application
    • tier-name
        • Flows >
          • Call from<tier>to<service>
            • Call from<node>to<node-or-service>
              • Individual Connection/Flow(<node> to <service>)
            • All Connections/Flows for Network Link(<tier> to <service>)
          • All Connections/Flows for tier
TCP Flow Metric Descriptions
Default Monitoring Mode
# Client Limited
The number of TCP window updates sent by a client node indicating that it is receiving data at a faster rate than the application can process
KPI
# Client Zero Window
If a client's TCP buffer is full, it sends Zero as the TCP receive window size to indicate that it cannot receive more data. The data transfer then stops until the client can process the data in its buffer.
A high rate of Client TCP Zero Window messages indicates a problem with either:
  • The TCP configuration on the node, or
  • The client-side application using that flow
KPI
# Connection Errors
The sum of Syn Resets+Syn Blackholes+TCP Resets - Established
KPI
# Connection Requests
The total number of connection requests (successful and unsuccessful) sent during the selected time window KPI
# Current Established Connections
The number of established (setup) flows/connections KPI
# Data Retransmits
Number of TCP data packets that were retransmitted for all TCP Connections KPI
# Delayed Acks (Data Piggy Back)
The average number of times a receiving node sent an ACK (acknowledgment) by "piggybacking" the ACK onto another message Advanced
# Delayed Acks (Timeouts)
The average number of times a receiving node sent an ACK (acknowledgment) because the Delayed ACK timer expired
This is a "worst-case" delay for the Delayed ACK algorithm and occurs most often when Nagle's algorithm and Delayed ACK are enabled on the sending and receiving node, respectively. A high rate of delayed ACKs may contribute significantly to the average Latency on a Connection.
Advanced
# Errors
The number of TCP messages sent indicating an error in setting up the connection (SYN errors), or tearing down the connection (FIN errors) KPI
# Fin Errors
The number of errors generated while tearing down the connections (TCP FIN errors). Many connections in FIN wait states can cause delays in creating new connections.
KPI
# Flows (<1KB)
# Flows (1k - 10k)
# Flows (10k - 100k)
# Flows (100k-1MB)
# Flows (1MB - 10MB)
# Flows (>10MB)
Use these metrics to analyze the distribution of flows by throughput
Advanced
# Flows - Handshake (1SD)
# Flows - Handshake (2SD)
# Flows - Handshake (3SD)
The number of TCP flows with connection-setup times that are 1, 2, or 3 Standard Deviations outside (higher or lower than) the average for that connection group
Under ideal conditions, all flows should be within 1SD of the average
Advanced
# Flows - Lifetime (1SD)
# Flows - Lifetime (2SD)
# Flows - Lifetime (3SD)
The number of TCP flows with lifetimes that are 1, 2, or 3 Standard Deviations outside (higher or lower than) the average.
Under ideal conditions, all flows should be within 1SD of the average. 2SD or 3SD flows indicate inconsistent flow treatment along the network path. These inconsistencies can occur when a network service decreases the available bandwidth intentionally (bandwidth throttling) or prioritizes some types of traffic over others (traffic shaping).
Short-lived connections, even if they are intermittent, may indicate an issue worth investigating. The more short-lived connections get generated, the more resources are spent setting up and tearing down these connections.
Advanced
# Flows - RTT (1SD)
# Flows - RTT (2SD)
# Flows - RTT (3SD)
Number of flows whose Round Trip Times are 1, 2, or 3 Standard Deviations higher than the average for all flows in the parent group. Under ideal conditions, all flows should be within 1SD of the average.
High-RTT connections, even if they are intermittent, may indicate an issue worth investigating. If the average response time for an eCommerce web app is two seconds (acceptable), but 5% of transactions are 20 seconds or higher (not acceptable), this can result in a significant number of unhappy customers and lost revenue.
Advanced
# Flows - TCP Data Rxmt
Number of flows within which any packet was retransmitted. Retransmissions are an indication of packet loss. Advanced
# Flows - TCP Resets
The average number of flows that were closed by a TCP Reset
KPI
# Flows - w/o TCP SACK
Number of flows with the TCP Selective Acknowledgment (SACK) option disabled. With SACK enabled, a receiver can send SACK packets to acknowledge receipt of multiple data packets in the case of lost segments. This improves network performance by reducing the number of retransmissions. With SACK disabled, the receiver must resend all the packets after the last lost segment, even if they were received by the peer.
Advanced
# Flows - w/o TCP Timestamp
Number of flows with the TCP Timestamp option disabled. Use this option to calculate more accurate Round Trip Times. Advanced
# IP Fragment Count
The total number of IP fragments attributes to this TCP connection group. A high level of fragmentation indicates network issues which can severely affect application performance. KPI
# Loss Pkts
The total number of packets that were lost (sent but never received) Advanced
# Nagle Delays
The number of times a message-send event was delayed because the sending node had to wait for previously-sent data to be acknowledged (ACK'd). This occurs most often when Nagle's algorithm and Delayed ACK are enabled on the sending and receiving node, respectively.
Advanced
# PIE Events
Use Performance Impacting Elements (PIE) to identify the location of actual or potential bottlenecks:
  • Client Limited and Client Zero Window events indicate a possible problem on the client node
  • RTOs indicate a possible problem on the network path between two nodes
  • Server Limited and Server Zero Window events indicate a possible problem on the server node
KPI
# RetransmissionTimeouts
Retransmission Timeouts (RTOs) indicate network packet loss which results in retransmission of data when the TCP retransmission timer expires (Timer to make sure data is ACK'ed)
  • This timer varies from 200ms-3 sec by default (different for each operating systems and their versions)
  • It causes severe performance degradations because a considerable amount of time is wasted resending lost data
  • TCP falls back to the "Slow Start" phase impacting the performance even more
KPI
# SACK Retransmits
Average number of packets that were retransmitted due to a SACK message that indicated an unreceived packet KPI
# Server Limited
The number of TCP window updates sent by a server node indicating that it is receiving data at a faster rate than the application can process
KPI
# Server Zero Window
If a server's TCP buffer is full, it sends Zero as the TCP receive window size to indicate that it cannot receive more data. The data transfer then stops until the server can process the data in its buffer.
A high rate of Server TCP Zero Window messages indicates a problem with either:
KPI
# Syn Blackholes
The number of connection attempts that went unanswered and resulted in a failure. Syn blackholes can severely impact application performance.
KPI
# Syn Resets
The number of connection attempts that were explicitly refused by the other host. Syn resets can severely impact application performance.
KPI
# TCP Resets - Established
The average number of times an established TCP flow was reset
KPI
# TCP Resets - Fin
The average number of times a TCP flow was reset while it was in the process of getting closed KPI
# TTL Changes (1 - 2 hops)
# TTL Changes (3 - 4 hops)
# TTL Changes (>=5 hops)
The number of routing-hop changes experienced by this connection. Frequent variations in routing-hop changes indicate routing problems in the network and can severely affect app performance.
Under ideal conditions, the number of hops should be consistent.
Advanced
Avg # TTL Hops
The average number of routing-hop changes experienced by this connection Advanced
Delayed Acks Lag (usec)
The average amount of lag that Delayed ACKs are adding to the overall Latency of the Connection Advanced
Initial RTT (usec)
Round trip time for the initial two SYN packets (between SYN and SYN-ACK, or SYN-ACK and ACK depending upon whether the Agent is running on client or server)
KPI
Latency - RTT (usec)
Average round-trip latency (from packet transmission to acknowledgment) for all packets
KPI
Lifetime (usec)
Average lifetime (from initial setup to final teardown) for TCP sessions in the Connection group KPI
Loss (per mille)
The number of packets lost per 1000 packets sent. "Per mille" is a percentage with one additional digit of precision. KPI
Nagle Delays Lag (usec)
The average amount of lag that Nagle delays are adding to the overall Latency of the Connection Advanced
Pkts per Sec
Average rate of packets sent and received KPI
Rx Pkts per Sec
Average rate of packets received Advanced
Rx Throughput (BPS)
Average rate of bytes received Advanced
TCP Handshake (usec)
Round trip time for the initial three-way connection setup for all flows in the parent group:
  1. SYN (client --> server)
  2. SYN-ACK (client <-- server)
  3. ACK (client --> server)
KPI
Throughput (BPS)
Throughput (bytes per second) for the application of interest on all TCP sessions KPI
Tx Pkts per Sec
Rate of packets sent Advanced
Tx Throughput (BPS)
Rate of traffic received Advanced
