Default Values for Smart Agent CLI Utility Flag Options
Important: The Smart Agent CLI is deprecated and will reach End of Support on February 2, 2026. Until then, only critical security fixes and bug fixes will be provided and a release will be made as needed.
It is recommend to use Smartagentctl instead of Smart Agent Command Line Utility. See Install Smart Agent.
Option Default Value
version string (latest) ( -v )
profile string (default) ( -p )
config string ( -c )
install-dir string ( -d )
app-name string ( -a )
node-name string ( -n )
tier-name string ( -t )
inventory string ( -i )
connection string ( -q )
hosts string ( -m )
install-agent-from string ( -l )
backup string ( -l )
attach-configure-file string ( -f )
latest
default
/opt/appdynamics/appdcli/config.ini
local
all
false
